About PolyRegion Clerance Violation In Altium 19
mulfycrowh , 04-01-2019, 04:30 AM
Hi everyone,
As shown on the attached screenshot, I have violations between Polyregion and Pads on a component.
I didn't find the rule in Design > Rules > Clearance.
Could you please tell me where I change the rule from 10 mil to 8 mil ?
Thanks a lot.
robertferanec , 04-01-2019, 09:00 AM
Is the exposed pad a pin or polygon? Exposed pad should be a pin.
mulfycrowh , 04-01-2019, 09:07 AM
Thks for reply.
If I click on the exposed pad, I get this:
robertferanec , 04-01-2019, 09:22 AM
that could be the problem. I would go to footprint library, delete the polygons and make the pad the size you need. That should help.
mulfycrowh , 04-02-2019, 02:20 PM
I removed all the regions and I do not have any more violation.
The trouble is that, according to the datasheet, the exposed pad should be like the attached footprint.
If I add this two areas on left and sight sides (as regions), I have violations.
How could I manage this ?
mulfycrowh , 04-04-2019, 01:05 AM
Is there anybody to answer please ?
mairomaster , 04-04-2019, 05:56 AM
Be more specific please. On your later screenshot I can't see any violations. Are you getting clearance, short circuit or what? Between what and what?
mulfycrowh , 04-04-2019, 07:53 AM
As already explained, the violation is between the solid region and the pads.
Paul van Avesaath , 04-04-2019, 02:10 PM
if your right click and look at the violations, you should be able to see which rule is triggering this error.. also could it be that you might have a netname issue doing it like this? (i mean with the pads and the EP connected to each other)
mulfycrowh , 04-04-2019, 02:47 PM
Thanks for reply.
Here are the details of the violation.
It is between the solid region I added on top and bottom of the EP (Pad 21) and a pad.
The question was: where can I find in the rules the clearance between a solid region and a pad ?
mulfycrowh , 04-06-2019, 02:45 PM
Could you please tell me where I can find the settings for the clearance between a region and a pad ?
Paul van Avesaath , 04-06-2019, 03:01 PM
If you click on the blue word clearance, it should take you to the rule that is triggering! So click it and change the value and see what happens..
mulfycrowh , 04-06-2019, 03:12 PM
Here is the dialog I get when clicking on the blue word clearance.
Sorry but I don't see the rule that triggers the violation.
The object in conflict with the pad is not a pad. This is a region.
Where is the rule ? It is set to 10mil.
Paul van Avesaath , 04-06-2019, 04:34 PM
Either copper to copper or copper to smd pad..
To verify this is your rule change all values to 5 and see if it still triggers
Paul van Avesaath , 04-06-2019, 04:36 PM
In some cases I have created exceptions in the rules for some footprints.. If I can't get them right within the scope of the rule.. It is a trade off, but keeps you sane...
robertferanec , 04-07-2019, 11:31 PM
@mulfycrowh is not a custom shaped pad something what you are looking for? https://www.altium.com/documentation...ad+Shapes))_AD
mulfycrowh , 04-08-2019, 10:25 AM
@robertferanec Robert, I tried something I thought it would run but it doesn't: I have the square pad (21) in the middle and for the sides I used fills.
Same result: violation between Fill and Pad.
I do not see the solution.
mulfycrowh , 04-08-2019, 10:53 AM
So I found it.
There is an advanced mode in the rules dialog and you can set up the clearance about the fills without any problem.
So I set it up according to the picture below and NO MORE VIOLATION !
Paul van Avesaath , 04-08-2019, 03:09 PM
cool thanks for sharing!
