Hi Robert how are you? I try to convert Allegro *.brd file to Altium Designer 19 *.PcbDoc, but i can't. I find a few solution on web but the are not solve my problem. Like the shows below. https://nilsminor.de/index.php/2018/...m-pcbdoc-file/ https://www.altium.com/documentation...ro+Import))_AD Would you please give same idea how to solve this. Best Regard, Taner
Allegro .brd PCB to Altium .PCBDoc
Hi Robert how are you? I try to convert Allegro *.brd file to Altium Designer 19 *.PcbDoc, but i can't. I find a few solution on web but the are not solve my problem. Like the shows below. https://nilsminor.de/index.php/2018/...m-pcbdoc-file/ https://www.altium.com/documentation...ro+Import))_AD Would you please give same idea how to solve this. Best Regard, TanerTags: None
And where exactly is the problem? What step doesn't work? Install OrCAD Lite (it's free), then go to Altium and use import (I do not have access to Altium right now to describe the steps exactly, but you should be able to find the import in main menu).
You need to find where the exctracta.exe file is located and you need to add the PATH into you environment.
For example in my case it is located in "D:\Cadence\SPB_17.2\tools\bin" so I had to add it into START -> right click on My Computer -> System properties -> Advanced -> Environmental Variables. Then, in System Variables, select Path, Edit and add ";D:\Cadence\SPB_17.2\tools\bin" at the end. After the change, you will need to switch off and switch on Altium.
Hi Namvar,
you can try with attached files.
Best Regards,
Taner.Attached Files
I used the method above, but the imported PCB does not have any track and plane (No cupper ) in all layers.
