BGA Via size
    shereesubahan, have a look at our OpenRex open source project - that is using 0.8mm BGA.
    Here is link to the project, you can download there Altium files: https://www.imx6rex.com/open-rex/
Name:	bga 08 fanout.png
  • Paul van Avesaath
    this might help
  • Lakshmi
    You stated that minimum Clearance between the pads is 0.2mm. Is this information given in the datasheet?
    Could you please share the Part Number?
  • shereesubahan
    pad size is .45mm X .45mm, pitch is 0.8X0.8mm, Minimum clearance is 0.2mm in this spec if we use above 18Mil annular ring and 8mil hole , getting clearance error wit adjacent pads
  • Paul van Avesaath
    i normally use 18Mil annular ring and 8mil hole
  • shereesubahan
    started a topic BGA Via size
    BGA Via size
    What can be the via size of 0.8 X 0.8 mm pitch 484pin-BGA, Trace tickness
