Schematic title block editing
  • Schematic title block editing
    Can someone please explain to me how can I fill the schematic title block fields?
    I couldn't find online any information about it.
    I am using ALTIUM DESIGNER 18.
    Sasha
    Hi Sasha,
    do you mean this? (see picture)
    In this case, you need edit the template file, should be in your C:/Users/public/Documents/Altium/Ad18/Templates and edit or create a file named *.schDot and add field as you need puting text and using the prefix =. For example: my field Project I use: Project: = ProjectName.
    Save with extension *schDot and now you can use it as template proyect sheet
    Hope you find useful.
    REgards
Name:	Anotación 2019-10-22 075338.png
    • Sasha.A
      Sasha.A commented
      Editing a comment
      How can i choose new template for my current project?
    • Sasha.A
      Sasha.A commented
      Editing a comment
      How can I update the fields of the title block?
    right click in schematic and choose document.. otherwise tools -> update paramters and only select documtent.. now all field that are user fillable are there for you to fill in..
    • Sasha.A
      Sasha.A commented
      Editing a comment
      did it, but the fields are still empty.
    Do you have convert special strings on in Settings?
    • Sasha.A
      Sasha.A commented
      Editing a comment
      Sorry, but I don't know which settings you mean.
    Thanks, guys, I succeed!
    • #6
      You can also hide the default title block and create your own. In Schematic symbol library, draw your own title block, set Type to Graphical and you can use it. I may be doing video about this.
      PS: You can put there Project parameters, so it will fill out automatically. I attached also the library file.
      PSS: Sasha.A please do not delete your previous comments so the post makes sense. Thank you.
      Click image for larger version  Name:	custom title block altium.png Views:	2 Size:	171.4 KB ID:	12233
