Help!! I don't see any component outlines or designators on top/bottom layers even if I enable designators in the property window. What should I do? See attached.
Lost my designators and component outlines
Please do not attach docs, most people will not open it. The best is to attach pictures.
PS: Do you have the layers enabled? Try left click on LS button and select All Layers
👍 1 -
Hello mstamler ,
It seems you have accidentally used the shortcut "Shift+S" which took you a single layer view mode.. (Happens with me at times.. 😁)
Follow robertferanec 's suggestion to view all the enabled layers of the design.
P.S,
"Shift+S" enables you to cycle through your view mode of enables layers from Single layer, All layer and No layer.
Thanks.Comment
