Altium PCB Origin
    yes, you can set origin anywhere.
  • Nigel Bishop
    Hi Robert, this is not quite what I meant, in your video, where you set origin to bottom left corner of board (Edit>Origin>Set) can you select a pin or pad at this point
    it is in drill config (in your job file, right click in Fabrication outputs -> NC Drill Files -> Configure ):
    Click image for larger version  Name:	drill zero.PNG Views:	0 Size:	92.4 KB ID:	14194
  • Nigel Bishop
    started a topic Altium PCB Origin
    Altium PCB Origin
    How do you change the Origin to a drilled hole, I never normally use a board edge
