Pad connection in library!
  • WhoKnewKnows
    IIUC, what you're trying to do is done with another type of component called a net tie. I recommend using a net tie component to connect the two nets together, then use the component where you were trying to join them as you would normally.
  • JohnsonMiller
    goncaloc , did you check DRC? you most probably will see short circuit error.
  • goncaloc
    Hi Johnson
    Usually I name both pads the same
  • JohnsonMiller
    started a topic Pad connection in library!
    In a library and footprint design of a component I need to connect two PADs, I did so but in the PCB and DRC I am receiving a short-circuit error! How we can avoid this error?
