28Pins-Udemy.
  • GCopper
    Got it, Thank you very much!
    In AD18 and higher use Properties panel instead of PCB Inspector (you do not have to use PCBLIB List). Simply select all the pads and in Properties panel change the properties.
  • GCopper
    started a topic 28Pins-Udemy.
    28Pins-Udemy.
    I need help following this step using AD19. The AD19 replaced the PCB Inspector with PCBLIB List. How to adjust or edit the solder mask expansion?
    Thank you. Click image for larger version
Name:	Increasing the space between the pads.PNG
