Report of signals connected to a component
    I don't know. What are you trying to do?
  • WhoKnewKnows
    Thanks!
    I'll check it out.
  • qdrives
    It depends a bit on what you want to do.
    First of, perhaps the Navigator can do what you want.
    - Validate the project
    - In the navigator panel select flattened hierarchy
    - In the instance, select the component
    - Open to the pin(s) you want to see connections to
    - At the bottom in the Net pins section you see all the connections (pins, ports, netnames, sheet entries) to which it is connected.
Name:	Capture navigator.png
    Alternatively I did make a script years ago that creates a human readable connection list as Altium was also used for electric wiring.
    But that scripts lists all nets and is a per net basis.
  • WhoKnewKnows
    Thanks for any suggestions 👆
  • WhoKnewKnows
    started a topic Report of signals connected to a component
    Hello people,
    If my schematic has a large pin count MCU and I want a report or listing of all of the signals connected to the MCU, can Altium generate this? Perhaps a portion of the netlist that is specific to nets that connect to the MCU?
