problems with routing
Hussain92 , 02-07-2016, 11:26 PM
Hi Rebert ,
I have some problem in my PCB project when i'm checking the error ..
The most problems are :
1.Un-Routed net constraint :Net GND ...
2. NET Antennae:via ...
> I'll post pictures .
robertferanec , 02-08-2016, 01:00 AM
Hi @Hussain92, try to browse through your violations: use PCB Rules and Violation window (go to your PCB, go to the bottom right corner, click on PCB -> PCB Rules and Violations). Browse through the Rules, double click on Violation and try "Jump" & "Highlight" buttons. See the attached screenshot. That will help you identify the places with errors.
Hussain92 , 02-09-2016, 12:55 AM
Thanks robert but I know how open the Rules and Violations window but i can't solve the problem and u can see in pictures all the errors about GND via .
*I'll post the pictures .
robertferanec , 02-09-2016, 01:07 AM
It looks like you have not configured GND plane. You will need to set stackup, and then go on the layer which should be GND, double click on your PCB and assign the layer a net. This will help you (watch from 4:08): Altium – Stackup Manager (The New & Old Way)
Hussain92 , 02-11-2016, 01:16 AM
thanks Robert , most of errors is gone .. just remained 4 errors
robertferanec , 02-11-2016, 03:36 AM
Perfect The rest of the errors are un-routed nets - you just need to connect them. They may have part of signal routed, but somewhere on the way it is still not connected. If you are not sure, just re-route the connections.
