Footpring manager
    Try to use "Update from library" and check if the components are using correct libraries. Have a look here >
  • mairomaster
    Not quite sure what is happening without having you setup. A thing you can try is to include the particular library to you project and to make sure all the footprints link to this library. Then you shouldn't have problems.
  • chris007
  • chris007
    started a topic Footpring manager
    Footpring manager
    I am experiencing something very weird with the footprint manager. When I allocate and validate the footprint change of some component, the footpring manager ECO , I validate and execute and everything goes fine. However later when I try to update the PCB the ECO tll me footpring is not found
    When I edit manually each component one by one it works properly. I have only this problem with the footpring manager, I don't understand why it doesn't work
    I attach screenshot picture in two post as there is limitation on the forum.
