AD16.1
When you are routing or moving components around try to hold CTRL, it should disable the snap to component hot points and snap only to grid.
EDIT: Sorry, didn't see the second page of the topic and actually posted the same reply as RobertLast edited by mairomaster; 07-03-2016, 02:52 PM.
- 1 like
Another unwelcome feature in new AD which shows up in component placement and routing, is mouse pointer locking to nearby item! any idea?
JohnsonMiller I believe, mairomaster answered your question. They changed number of default settings ...
From the preferences, try PCB Editor -> General -> Display Popup Selection Dialog.
- 1 like
Robert, thank you for your comment, I went through documents and recovered some features,
However an issue still exist. Consider a sample PCB with components on both sides, in old AD when you make a click a small selection menu appear helping to select proper component, while in new AD, you have to keep mouse pointer in absolute stationery and with each click it cycle among components, very boring and inaccurate process. Any help?
Originally posted by mairomaster View PostThe most noticeable one is the introduction of Draftsman, which I tried for 10 minutes and realised it is quite crap at this stage. Probably they will make it better in the future.
Another issue appear on PDF export, color in PDF is different from PCB and setting color from dialog box does not fix the issue, have to import from PCB and need to do it twice to see the effect!!!
I think updating the defaults was a good thing. There were many legacy options which are not used nowadays and also many options which by default are not the way the most people use them. Before I needed to change lots of the default options to be comfortable, now I don't need to change that many. I can see how it could be more of a problem for people which relied heavily on the old default. For me it took just 15 min to go through the changes list and re-adjust a few things.
Originally posted by robertferanec View Postecworks, looks like Altium has made a lot of changes in the default preferences, have a look at the whole Changes to Default Altium Designer Preferences page.
​thank you...got the technic to highlight track...we need to press shift button then place the mouse pointer on the track then we can highlight the whole track..otherwise go to DXP-> preference ->PCB editor->board insight display-> and here there is an option live highlighting in it we can disable "live highlighting only when shift key is down"....after disable this option it will work as previous... thank you friends for your supports
Thank you Robert,
Very strange! why these guys making these level of changes on handy command and shortcuts?
Thank you mairomaster, that is exactly the page where I have seen it.
JohnsonMiller, I think this is what you may be looking for "SYSTEM - DESIGN INSIGHT" default settings have changed: http://techdocs.altium.com/display/A...eferences))_AD
