about the pad
    CORTEX, as mairomaster mentioned, your mounting hole PAD diameter should be at least as large as the screw head, otherwise it can make short circuit between your plane and mounting hole.
  • mairomaster
    I am afraid I don't speak Turkish :P
    EDIT: Ok it is in english now
  • CORTEX
    up to the diameter of the screw hole made of solder coated with
  • mairomaster
    I forgot to mention that you also need a keep-out shape, so that polygon pours and other copper won't get into the area - otherwise your risk the screw head to damage something. The easiest way to achieve this is to create the arc on the top layer, to define it as a keep-out (from properties) and to set a solder mask expansion (could be from rules).
    However, in general that is not a very good approach in my opinion. I create my mounting holes the same way as Robert - using simple TH pads with a pad diameter big enough for the screw head. Apart from no need to worry about keep-outs, there is a copper surface below the screw head which in theory makes the mounting hole a bit more durable. It also looks better in my opinion and it is the most common method of creating mounting holes.
  • CORTEX
    Hi Thanks
    I did solder pad externally around the upper.
    could be the correct method ?
    Best Regards
    We just create a component called Mounting hole (in schematic it is a simple 1 pin symbol, in PCB it is a simple PAD). You can check it in one of our projects e.g. download OpenRex Altium files: http://www.imx6rex.com/open-rex/ or our 28Pins project: http://www.28pins.com/download/
Name:	mounting hole symbol.png
Name:	mounting hole footprint.png
  • mairomaster
    Hi CORTEX,
    The mounting hole you can do in different ways. The one in the picture consists of a TH pad with 0 pad size and a particular hole size. Also they have probably used a 360 degrees arc on the Solder Mask layer with a particular width, to create the exposed solder mask region for the screw head.
  • CORTEX
    started a topic about the pad
    about the pad
    Hi Robert
    I have a question for you.
    the shape in the picture I have sent in Attachment How do I do it.
    Best Regards
