How to Cross Probe net then Reposition Selected Component without losing highlighting
  • How to Cross Probe net then Reposition Selected Component without losing highlighting
    I am working through one of the courses and see that a net or pin can be cross probed, which is then highlighted in the PCB, then select a component in the schematic and use Reposition Selected Component in the PCB, but when I go to select the component I lose the net highlighting.
    I've uploaded a short clip of what I am doing on YouTube. I select Cross Probe, left click the VIN pin, right click to cancel the cross probe, left click the capacitor which then deselects the net highlighting.
    This will help you: https://www.fedevel.com/academy/updates/ especially this: https://www.fedevel.com/welldoneblog...e-new-old-way/
    Basically, Altium has broke that feature
      Thanks Robert, I forgot to check that page for the new "features".
      I tried following the new way but I am getting the same issue, see this clip
      However, I am pretty sure when I tried this on my work machine it worked - I will retry this and post the results. Both machines are running 17.1
      I did notice that if you hold shift when making the first selection - I'm not sure if you are doing this or not in your video - that it works the same or similar to the old way, see this clip where I hold shift when selecting the first component
        Tom, the SHIFT trick is NICE!!!!!! I tested it in AD17, it works Thank you!
          Glad to have helped
          • #6
            Hello Robert,
            I am working on Advanced PCB Layout Course and I have the same problem with Altium 20
            Maybe something wrong with PCB settings.
            Do You know such problem with new Altium version?
            highlighting loses every time when I press reposition selected component.
            • #7
              This will help: https://www.youtube.com/watch?v=Q26CjD85J44
              • #8
                Thank You Robert,
                Altium changes the UI between versions and If I correctly understand in version 20 is not possible "reposition selected component" in dim mode. Diplay will becom colored after presing that button.
                • #9
                  The video is in AD20 and yes, it is not as good as it used to be
                  • #10
                    An excellent tip from Marek! Thank you.
                    Be sure that in Preferences->PCB Editor->Display you UNCHECK these two options:
                    - Apply Mask During Interactive Editing
                    - Apply Highlight During Interactive Editing
                    When these settings are unchecked, when you will be placing components, the mask will stay ON!
                    • #11
                      I ran into the same problem on AD23. To make it work I have to do both, uncheck the two options and hold shift while making the selection(s).
                      • #12
                        For shift click to select:
Name:	Capture shift click.png
