Yes, the problem is regarding the text inside the connector which is pulled over the pins descriptions, when trying to export the schematic as pdf. I will try to make the connector wider.
Thanks,
Vlad
Problems when generating pdf file
Do you mean the text inside connector? If it should not be there, you may want to remove it. If it should be there, then you may need to make the connector wider. I am not really sure, what the problem is.
Hi there,
I have some problems when I am trying to generate my schematics in to a pdf file. Please find the snapshot attached with the problem occurred.
I am using AD 16.
Please let me know if you have some solutions to this kind of problem.
Many thanks,
Mihai1 PhotoTags: None
