Problem in making gerber file in Allegro 17.2
Armin , 04-14-2019, 05:25 AM
Hi
I have 2 question in making gerber
I want to make gerber file in Allegro 17.2 but when I want to create artwork I 'll face with this error:
Photoplot outline rectangle not found; using drawing extents.
I didn't face with this error before in 16.6.
What can I do for resolving this issue?
Another question:
What is the differences between Outline layer and Cutout layer? In 17.2 when I want to make gerber gives me a warning to use Cutout instead of Outline. I used always the Outline layer in 16.6 and have not any problem before. is it important to be Cutout?
robertferanec , 04-18-2019, 02:46 AM
- Maybe this will help? https://community.cadence.com/cadenc...ngle-not-found
- I am not sure. Do you have a hole inside PCB which is expected to be marked as cutout? Outline is usually around board, cutouts are usually holes inside PCB.
Armin , 04-19-2019, 10:31 PM
[QUOTE=robertferanec;n10532]
I saw that link before. Oldmouldy told "It's a warning message that can be safely ignored. " I think I can ignore this error.
No I have not used hole inside the board also I used Outline for around board. I think there is some differences between 16.6 and 17.2. Is it right?
robertferanec , 04-25-2019, 05:42 AM
I think, in 17.2, for board outline you need to use Design Outline layer. Maybe that could be the problem?
Armin , 05-01-2019, 02:15 AM
I added Both "CUTOUT" and "Design_outline" to my films but unfortunately still I have the warning.
robertferanec , 05-01-2019, 07:42 AM
Hmm, I do not know Maybe I would try to design a very simple board to see if there is still the problem or I would open a different 17.2 design and check if there is the problem.
Armin , 05-03-2019, 11:04 PM
I wish that. If you could please inform me. Thank you so much
robertferanec , 05-05-2019, 10:32 AM
- I am not sure what you mean. I meant, if I was in your situation I would try to design a simple board or I would try to open different design to see if the problem is project specific or if it is something with installation or settings. Hope this helps.
