"Save part as" in orcad 17.4 Problem
M. Namvar , 08-11-2020, 09:44 PM
Hi
Double click on the part ,select file menu ,save as ....
it brings save lib as and i can not find save part as .
help please
robertferanec , 08-14-2020, 07:07 AM
I think that is fine. Have a look here: https://youtu.be/b8arWWrMGXA?t=218
PS: Unless the new orcad has some new options to save only parts(?)
M. Namvar , 08-17-2020, 03:43 AM
I have found another way for this problem in orcad 17.4
and i use it.
i follow these steps
1-Create default components with all parameters / properties required for the BOM (like description , supplier part number, manufacturer,..SCHChechecked ,....) with initial default values ('0' for numbers,'-' for text ,....)
2-save it as _DEF_.
before creating any new component
3-right click on _DEF_ and copy.
4-rename _DEF_ to _DEF_1
5-right click on lib and paste.
now you have two components _DEF_ and _DEF_1 .
6-rename the _DEF_1 to new component and continue.
i think it is a good alternative way . with all default initial properties/parameters are set to empty or '0' or '-'.,the possibility of entering previous values ​​is also eliminated.
