Mounting holes with grounding
  • Mounting holes with grounding
    Hello everyone.
    I'm curious about what is the best way to create mounting holes with grounding vias.
    There is no problem with creating a plated/non-plated mounting hole. It just needs to create a padstack and add it to the mechanical symbol and additionally Route Keepout and Package Keepout areas and it's done.
    My first approach to create a mounting hole with vias was by creating a mechanical mounting hole padstack with the diameter of 3.2 mm with such properties
    Drill hole typ - Circle
    Drill diameter - 3.2mm
    Hole/slot plating - plated
    Design layers - Begin/Default/End - 3.4 mm
    Then, I created a footprint as a package symbol. Around the footprint, I added an Etch layer on two sides (top and bottom) and 8 vias (0.4mm drill diameter, 0.8 mm layers)
    The maroon circle is a Package Keepout layer.
    Click image for larger version  Name:	mh3.PNG Views:	0 Size:	10.4 KB ID:	16890
    That's how it looks like right now.
    Even if add plated mounting hole, there is no connection between plating (1) and layers (2).
    Click image for larger version  Name:	layers.PNG Views:	0 Size:	77.0 KB ID:	16891
    How do you deal with creating such mounting holes? What is, in your opinion, the best way to create a proper mounting hole with grounding?
    I'm not going to use any paid tools which would do that for me.
    Yes this is the best way to design the Mounting holes with Ground vias. It doesn't matter weather you use plated/non plated Holes. If you want to use these holes for GND or Shield, then use them as plated. Otherwise no need for plating.
      This may also help: https://designhelp.fedevel.com/forum...s-in-schematic
