Symbol Type filter during decoupling capacitor placement under BGA
znp2015 , 03-07-2023, 07:11 AM
Hi All,
I am doing the advanced PCB course in Allegro. when I want to place the decoupling capacitor, the CPU is also selecting and I should do some effort. Is that any way that dim or Symbol Type filter that only the capacitor on the bottom side can be selected for placement?
Thanks in advance.
Best Regards,
Mostafa
znp2015 , 03-07-2023, 09:59 AM
@robertferanec Thanks! I have used this shortcut from your video in the youtube:
Connecting pads, drawing tracks, placing VIAs, doing fanout, moving & sliding tracks, adding shapes, creating shortcuts. Find the complete course at: http://...
when I press w on bottom layer, the CPU on the top will not highlighted.
#hover over pad, press w to start layout
funckey w "prepopup;pop dyn_option_select 'Selection set@:@Clear all selections' ;FORM find all_off; FORM find pins YES;FORM find cline_segs YES;FORM find vias YES;done;etchedit;prepopup;pop dyn_option_select '@:@Move'; move"
Thank you so much. ​
robertferanec , 03-08-2023, 07:51 AM
- In Altium, when a component is locked, it will not be picked up. I don't remember if that worked also in Allegro, you can try.
- Also, you can try to play with different modes. This may give you an idea: https://youtu.be/d_TPIxPX01s?t=4454
