Issue with PCIE mini port (OpenRex)
    Can you describe how did you enable the PCIe in kernel? How did you run menuconfig? You may need to run this whole command:
    make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- menuconfig
    It looks like, when you run menuconfig, yours setup doesn't know the TARGET.. Did you run something like this before going into menuconfig?
    make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6_defconfig
    Here you can find more info: http://www.imx6rex.com/software/how-...el_compilation
  • imsaditya
    Any solution as to how we can enable PCIe in the kernel? I'm using the Jasbir's filesystem and have updated the distribution...
    *** No rule to make target `menuconfig'. Stop.
    This looks to me more like problem with setup on host machine where you compile kernel. Maybe PCIE was not correctly enabled in kernel?
  • imsaditya
    started a topic Issue with PCIE mini port (OpenRex)
    The wifi card for PCIe mini was not being detected even after I tried to enable the PCIe port. I followed the instructions in [http://www.imx6rex.com/open-rex/soft...ls/#wifi_4965] website. The TeraTerm console constantly displays the error message ---
    And while executing the command lspci no PCIe devices were recognized as such.
    Kindly suggest how to enable the PCIe port for a wireless module and wifi module to be operated.
    P.S. The kernel I'm using is Jasbir's filesystem image and it doesn't have the required drivers. Kindly tell a solution for that too.
    With regards.
