About Duplicate track
zouhour , 04-21-2020, 08:38 AM
i correct the fault in my pcb library but i can't update it in the pcb and it is always shown like this :
robertferanec , 04-21-2020, 11:37 AM
I do not have access to Altium right now, but when you are in PCB library, find the footprint in the list, right click and Update PCB with XX footprint (or something similar)
zouhour, 04-21-2020, 11:41 AM
i have done these steps..even i updated the component in schematic sheet but the footprint of my project sheet still the same and does not change
robertferanec , 04-21-2020, 11:57 AM
did you save the library? is the footprint from the library you have corrected (select the footprint in PCB and check Properties)?
if nothing helps, delete the component from PCB and import it again from schematic
zouhour, 04-21-2020, 12:29 PM
it is an integrated library and i ve corrected the fault in its pcb library ...i have done all what u said but in vain
robertferanec , 04-23-2020, 07:03 AM
Does it work now?
zouhour, 04-23-2020, 07:12 AM
no unfortunately
robertferanec , 04-24-2020, 04:52 AM
Double check the Source of library, be sure symbols and footprints are pointing to the library you have corrected. It really should work oki:
zouhour , 04-26-2020, 06:16 AM
i check that source and it said that "component is not found in library" so i check my schematic library and i add the footprint again , i update schematic and i save all projects ..but after that it is shown like this :
robertferanec , 04-28-2020, 01:51 AM
There is still a problem with location of your footprint - looks like it is not correctly linked to the symbol. How did you add footprint in your library? Can you add screenshot of Projects panel with library and your project visible? I am not sure what kind of library you use.
Possibly try to add the libraries into your project:
zouhour , 04-28-2020, 06:36 AM
here it is the screenshot ..
PS: the footprint of the microcontroller is not correct .. i can't deal with it :/
robertferanec , 04-28-2020, 11:23 AM
When I used to work with integrated libraries, after we made changes, I think we had to recompile it or something like that (I do not have access to altium right now, but I can have a look tomorrow). Try right click on the integrated library and check the menu (I think it is the first item in the list)
zouhour , 04-29-2020, 08:12 AM
i recompile it but it doesn't work and the footprint is missing again .. :/
robertferanec , 04-29-2020, 11:44 AM
How did you add the footprint, please could you attach some screenshots?
zouhour , 05-01-2020, 03:11 PM
i click on add ==>browse==> i choose the footprint and then ok
robertferanec , 05-04-2020, 06:32 AM
@zouhour, please did you solve this?
zouhour, 05-11-2020, 04:19 PM
no but i add another component from another library..the footprint of my component is false and i can't deal with it
