You have to register before you can post. To keep this forum out of spammers, every registration is manually approved.
If you know answers on any questions on this forum, please feel free to answer them. (PS: I try to answer at least once a week or when possible, - Robert)
Polarized capacitors are usually for bigger capacities and are cheaper. However for polarized capacitors you need to be careful how to connect power (you need to follow the + and - signs on the capacitors).
For power supplies I often use non polarized, but these are more expensive and they only go up to certain capacities. For power supplies and decoupling, you would like to use capacitors with low ESR (when you are selecting capacitors for your designs, check ESR and voltage of capacitors used in reference board and find capacitors with similar ESR and same or higher voltage for your board). As I mentioned in your other post, this video may help: https://www.youtube.com/watch?v=h8di...ature=youtu.be
