220VAC to 5VDC
  • Filter
  • Time
  • Show
Clear All
new posts
  • 220VAC to 5VDC
    I was designing a circuitry in which I need to convert 220VAC to 12-5VDC for my signal circuitry and to ON/OFF the relay. I first chose SR086 as it was simple to implement (without transformer), but it turned out that the output current of SR086 is only 100mA. I need output current of around 400mA. Can anyone suggest me any good solution for that? I do not want to use the transformer as it would require a lot of space on my board. Thanks in advance.
  • #2
    I do not have experience with designing 220V devices, so I can't really help much. Maybe someone else can help?
    PS: We always try to use an existing power adapter as it makes certification a lot easier.
    • #3
      Yes, I am waiting for someone to response on this.
      May be I can use a block (220VAC to 12 VDC ) that can be fitted on PCB, if you recommend any. But, using an external adapter does not fit in my case :/
      • #4
        You can check these modules: HLK-PM12 Power module
        • #5
          Do note that mains supply has strict regulations to follow. Generally there is at least 3 or 6mm clearance required. 3mm for class I and 6mm for class II (double isolation). UL has other limits then EU. Either way, it will require a lot of space for this.
          • #6
            But do you know any design that I can implement myself on pcb for conversion of 220VAC to 12VDC?
            • #7
              No, the only things I had done were with transformer or use of approved supplies.
              But I do know ST has some components for it: https://www.st.com/en/applications/p...onverters.html
              or check Power Integrations
              https://ac-dc.power.com/
              • #8
                Ok. Thank you so much.
                Working...
