Hello Robert and other forum users,
I noticed in the advertisement for the Learn Altium Essentials Second Edition course -- which I just completed -- on this page there is a version of the board that is manufactured and assembled.
I am talking with a local fabrication house who can make six layer board, and have created a Bill of Materials that matches the template they use. I have also added four mounting holes on the corners of the board using pads with 2mm diameters to fit 2M screws – as an aside I have not connected the mounting hole pads to any nets, because I heard it would be bad design to connect them to signal ground.
The real reason I am posting is that I am wondering if I can test the board without connectors on the +VIN, +OUT2, and +OUT1 pads?
In the same video, I notice that Robert has wires from the power supply connected directly to the board, as well as the outputs connected to a load. How was he able to connect the wires to the pads? Did he just solder them directly on?
I will likely manufacture the board even if I cannot test it, but I am able to get access to a power supply and a load through my work, and would prefer to be able to test. I would appreciate any advice given.
Thank you,
Hayden
Thank you,
Hayden
