I have few confusions I would like to be clear about. Thank you in advance for answering the questions.
- Why do we use Multiple Via on Ground plate and Power tracks? Is it just because of the increasing current flow? If so is there any rule for using the number of via's or position of via's on the tracks based on the ampere(A)?
- Why do we use polygon in the top layer? We can just simply use the tracks and not use a polygon pour? Electrically the connections will be correct, So what's the purpose of a polygon?
- For multiple-layer, we need to match 50-ohm impedance. My question is how to do it? Is there any guideline for this?
- Where is the correct position for FIDUCIALS? Also, What is the major reason for FIDUCIALS?
- Why 3 of the MOUNTING HOLES are connected to ground in the Arduino design (28Pin's project) and one MOUNTING HOLE is not connected? Can't we just connect all four of those or not connected any of those to GND?
- There is a License layer which contains all the licence information of the project. Where can I find this licence information? Is it just from the Arduino website? Do we need to include License information for open-source hardware?
- Lastly, What information do we need to put on the Manufacturing Notes layers? Do you have a list or formate suggestion form this?
