Connecting Power net from bottom to top layer through via
  • Time
  • Show
Clear All
new posts
  • Connecting Power net from bottom to top layer through via
    Hello everyone,
    I would like to connect a power signal (+5V) from bottom layer to top layer through via. In my first implementation (picture1) I am using a single via on the power track although I was thinking that I could place a polygon poor and use multiple vias in order to connect the power signal from the bottom into the top layer, in that way I could create a lower impedance path for the power signal so I could ensure a greater amperage capacity for the track. I don't think that this is necessary for the specific application since there is no need for high amperage capacity (<1.5A) but I would like to ask if that's a good practice in that type of connections?
    Best regards,
    Andrew.
  • #2
    I am not sure what exactly is then connected from the bottom track (e.g. if only 1 component or half of the board .... or if it is a standard board or a high speed design, etc). But, for a simple connection on a simple board, one VIA can be just fine. For more components, I would use polygons with multiple VIAs.
    • #3
      On the prototypes build of my very first design there were "voids in the via's". Ever since I am very aware of via problems.
      For power lines I generally use two via's to connect traces IF it continues on a different layer to multiple connections.
      I also use(d) a simple rule of maximum 1A per via, so with 1.5A that already requires 2 via's. The best way to know how much current can go through a via is with the PCB toolkit (https://saturnpcb.com/saturn-pcb-toolkit/) Now I am working on a design where the via's are smaller and even micro via's and there I limit it to 0.5A per via.
      However, I do not use a polygon pour as a distribution point, but like the picture below.
Name:	Capture multi via.PNG
      Working...
