RS485 Baud rate
  • Filter
  • Time
  • Show
Clear All
new posts
  • RS485 Baud rate
    Hello there, i have designed a board with RS485 communicatin . i have used the MAX485 IC . My problem is that the communication is working very well when the baud rate is 9600 and when i try to increase it to 115200 for exemple it dosen't work ! .
    Please any idea to help me ?
  • #2
    Have you added 120 ohm termination at both ends?
    Make sure that the drive enable pin is made low as soon as the last stop bit is transmitted.
    • abdelkarim
      abdelkarim commented
      Editing a comment
      yes i added the 120 ohm resistor
  • #3
    how long is the cable?
    • abdelkarim
      Editing a comment
      the cable is <1 m
  • #4
    do two the same devices (e.g. your board talking to your board) talk to each other or are they different devices (e.g. your board talking to a PC)? the problem could be also inaccurate frequency of UART signal
    • abdelkarim
      Editing a comment
      my board is talking to a pc
  • #5
    Did you consider your MCU frequency based on timing accuracy for the UART at 115200?
    This is what I mean, here are some examples: https://www.google.com/search?q=mcu+...WGiOLdTofVh-9M
    Working...
