When updating the schematic library and coming back to the schematic I see the component not updated. For example, I want to change the pin distances so a resistor could fit in between the pins and I go to schematic library and change the pin distance on dual gate transistor and save. Is there a way the schematic would recognize the change and prompt or change it? What should I do for refreshing my schematic to changes in the library except deleting the part and placing it again?
I assume such capability has merits (it is a relational database I assume) and flaws (By changing the library one may affect several sheets and cause problems), what is implemented in Altium for this capability?
I think I will be doing this a lot from now on.
