Top Overlay vs. Courtyard
  • #16
    Wow this is more information than I could have imagined regarding IPC and footprint. Thank you very much for the info and sharing your experience. I like to ask you what would you suggest for my situation. In other words how should I proceed with my footprint libraries as a newbie. I like to follow a correct procedure. I will end up buying the Altium license for my startup in a year and will keep the license so I like to build the foundations correctly.
    With the differences you mentioned between PLE and IPC Wizard and the fact that, I would like to build my footprints such that I can be sure I would not have manufacturing problems and be as close to IPC as possible. Without having enough IPC knowledge and not having the document what path for building my footprints do you suggest? At the time I downloaded PLE but seemed very detailed. Do you think following Altium IPC wizard despite its lagging behind the latest IPC would be a good idea? Just because it is the shortest path to IPC?or do you suggest I put effort learning PLE and IPC and use PLE?
    The 3D modeling is amazing. Thanks for the tips and links. Seems I still have a long way to go.
    May be after I read IPC, I can ask my doubts on calculations from you. Thanks again.
    • #17
      It is a difficult situation, especially for a beginner (I was in the same situation half an year ago). If you want to be serious with this (and I think everybody should be quite serious when creating a base library of parts) it is worth it to at least buy the IPC standard. It gives you a good understanding of how different sizes are calculated and other useful things. However, even if you have the information, it is quite inconvenient to do all the calculations manually when creating the components. You can make mistakes, either by miscalculating numbers or due to a lack of proper understanding of particular issues.
      PLE is without doubt a great tool for creating a library, probably the best existing one. The full version which allows you to export components to Altium, etc., might be quite expensive though and I am not sure if the price would be justified for you. About the effort of learning it, it is worth it without a question. And it is not massively complicated anyway, if you already have some understanding of the standard. In many different topics in engineering it is a must to be as knowledgeable as possible, if you want to be a solid engineer.
      As already discussed, the Altium IPC wizard is not a bad tool as well, in my opinion. Altium 16 also generates nice 3D models for you. However, due to it's shortcomings you have to be quite careful. A good understanding of the IPC standard and cross referencing reliable existing footprints definitely helps to double check if the footprints generated by Altium are alright.
      Which tool you will select depends on your preference, your budget, how many footprints you will need to create, etc. Also keep in mind that for a lot of components the manufacturer specifies what footprint needs to be used and normally is good to go with that one, rather than going with the one suggested by IPC.
      Even if you are an expert in IPC though, unfortunately it is not always the holy grail, and it is not perfect in all situations. I have been editing/checking some BGA footprints a few month ago and according to IPC they were supposed to have unreasonably big pads. The manufacturer was recommending pads that are quite a bit smaller, although it seemed to be quite an ordinary BGA package. We decided to go with the manufacturer's recommendation rather than IPC and now the board using those footprints works great. If we went with IPC recommended sizes it might have been working well again, but we would not have had enough space to run tracks between the pads for example.
      • #18
        zeino, at least you can try PLE light and see what values it puts in final footprint- and/or run trial to get full library during the trial time: it's enough to build entire EIA packages family at the very least. What about IPC-7351 standard, it's worth to mention that in case of purchasing PLE you'll get free copy of it- but I want to cover this in context of mairomaster's words about non-ideal results under some circumstances: me, I always develop 3D for footprint because 3D checks footprint and vice versa, and some time it's clear that for example manufacturer's footprint is wrong, or calculated one isn't good enough- meaning PLE, I had some non-ideal footprints with side concave package, footprint pads didn't cover physical pads properly.
        What abour3D modeling itself- like it was said, there is no such software that covers all package nuances even for standard parts, so building stuff by your own is really great way as you gain control of the situation. Of course it's possible to search some free stuff on sites with 3D models, but my opinion it's not really good approach- there are a lot of authors which have their own very specific understanding of what is right and what is wrong, there are bunch of different methodologies and placing all such parts made different way makes you PCB look like mess. And I should say that control level is so high that you can even make parts which have bad or missing drawings in datasheet- here is example: BK-18650-PC4- incomplete drawings(for making 3D) and dummy original model(plain box).
        • #19
          In our designs, we usually draw the Top overlay as the biggest size of the component - so you are sure if you place two components close to each other with touching Overlay, it will be possible to fit them. In assembly layer, we draw a simple shape around the component, but we do not use this layer as the component courtyard - it's just to show component location.
          How do you get the maxsize of the component for example for a smt capa? I learned from your course that you use this pdf (https://www.ibselectronics.com/pdf/p.../smt_notes.pdf) for the footprint. Do you use the F and G value in the table to define the top overlay line?
          For my project I use CircuitMaker and I dont know if i have to trust the footprint done by someone else. It seems that anyway I have to draw at least silkscreens for the assembly drawings. And for some components for example they use courtyard layer. I didnt kwnow what it is. It is confused for me. Is this layer is mandatory for the assembly and also layout (placement)? can we just do as specified by Robert Feranec in his course(top overlay for placement)?
          • #20
            Yes, we use F and G, but when you are creating new components you may want to check if it fits there. Especially capacitors or beads may have different size occasionally.
            Altium doesn't support courtyard directly, that is why I do no really use it and we only use the overlay layer instead. In Altium, I normally use 3D models to check if everything fits ok. In the previous company, where I used to work, they used Allegro and they always created courtyard.
            • #21
              Do you mean for checking if components fits i have to print the assembly and buying the components and puts all of them on the assembly drawing paper?
              For the assembly it seems that the courtyard is not mandatory, am i right? When the courtyard is necessary, isnt it for placement only? And in your course you use top overlay as courtyard, right?
              • #22
                I will try to summarise:
                The courtyard is mainly used to ensure proper physical spacing between the components. If you don't have enough space between them, you risk to have problems during the assembly process, due to imperfections of the pick and place machine and variance of components' actual size. For electrical spacing different rules are used (e.g. copper to copper, minimum solder mask sliver, etc).
                Assembly houses don't normally need the courtyard information for the assembly process - the courtyard just helps you to create a design which could be assembled without problems.
                I personally prefer using a separate layer for the courtyard as it gives me more flexibility and the ability to do whatever I want with the silk screen. I also use the courtyard layer for assembly drawings.
                • #23
                  Thanks a lot for these precious information.
                  I was just a bit confuse because in the robert feranec 's courses he didnt mention courtyard. Now it is clear.
                  • #24
                    Hi guys,
                    Let me add few comments regarding mentioned subjects:
                    Yes, and this is significant fault of Altium- it does recognize courtyard as the entire footprint, means it allows overlap when rules covering gap between components are set to 0. You can compare it with Allegro, where “Placement Boundary” layer is courtyard layer- take a look at pic from attachment: if one try to overlap those boundaries that will give an error, however courtyard edge overlaps are allowed- which is correct and logical obviously. So Altium sucks here
                    Correct, it's not required for assembly completely, you only need it at design stage.
                    If you mean duplicating courtyard geometry also on silkscreen layer that generally is only possible when you use N and M pattern density according to IPC-7351, while in case of L you most probably will not be able to make such contour without violating “Silk-to-Copper distance”-like rules.
                    Now it is clear.
                    Meaning the exact requirement in courtyard definition: biggest benefit of it is possibility to achieve most dense placement while still remaining with IPC-7351, but it's obvious fact that far not all boards require that kind of placement. I'll tell you more, lot and lot of board are physically just oversized(artificially) to perform fast and easy component placement using grid- it's standard and mainstream approach, but it doesn't work in true high density designs. At the same time, placing components courtyard edge-to-edge in 90% of cases will lead you to high-end HDI designs area, but it's not main case: such placement isn't based on grid but on geometrical transformations thus being most complicated and time consuming method- however bringing the most high quality result by all means. If one doesn't have experience in such placement it's very easy to mess with your project in such way that will definitely turn into deep relayout/redesign
ID:	3401 Click image for larger version
                    • #25
                      Originally posted by EVW13 View Post
                      Hi guys,
                      [ATTACH=CONFIG]n3401[/ATTACH] [ATTACH=CONFIG]n3402[/ATTACH]
                      I meant I keep the two layers completely independent - each of them serves its own purpose. The courtyard is used for placement information/guidance as you explained and the silk screen is used purely for user information.
                      I agree that if only silk screen is used for courtyard purposes, you can't really have small L components, since you will not be able to meet the silk screen clearance (don't have time now to double check that).
                      With small resistors and capacitors I don't have silk screen at all. With some big component (ICs for example) the silk screen shows the body outline, while the courtyard is sort of an extended version of the body outline.
                      • #26
                        thanks for all these information.
                        1) But I dont understand what does it means "N, M or L pattern density according to IPC-7351"?
                        2) In which case am I? I am designing a simple board (soc ti am3358 + sd card + ddr3) just to make my first PCB and learn. The pitch of the soc is 0.8mm. I placed all the 0402 decoupling capacitors under the SOC.
                        3) I took a 0402 cap 10nF from the circuitmaker community. But I dont really understand, there are three versions of the footprint. I suppose a N, M and L version. And which one can i use to be able to place my capa correctly without overlapping each others?
                        4) And for all the footprints, there is something strange for the soldermask it seems that there is only one soldermask and not two. Is it correct?
ID:	3409 Click image for larger version
                        5) Last question, how to be sure that these footprint are IPC-7351 compliant? I downloaded PLE free version. Can I compare metrics of the footprint with footprint generated by PLE? Or maybe is it better to regenerate the footprint with the component wizard? For info i use CircuitMaker so I think i cant generate footprint for it. Maybe im wrong?
                        • #27
                          Hi ljo, please review my comments below:
                          1) N-Nominal, M-Most, L-Least, all these are pattern density definitions covered by IPC-7351. You said you downloaded PLE- you can check them in tab “Terminal->Density level”.
                          2) According to you your pic I strongly believe than L density will serve the best. However those footprints don't look like IPC-7351 compliant: subject was covered few posts earlier.
                          3) Yes, all those 0402 footprints are kind of “Circuitmaker understanding of IPC-7351”- once again, you can run your own calculations via PLE and then compare and see differences (they do exist). What about overlapping- while you're still doing correct placement density level doesn't matter, courtyards shouldn't be overlapped(except edges) under any circumstances. Also, just to repeat myself: courtyard edge-to-edge placement is gridless in general and only can be achieved by geometrical transformations.
                          4) I don't understand, can you explain?
                          5) See p.1, just run your PLE and compare results.
                          P.S. If it's your first project I strongly recommend you to start from SMPS layout: there is no challenge in routing DDRx memories when you do understand design guidelines, however polygonal layout(Power and Ground + Switching nodes) is exactly kind of thing where 95% of PCB designer fail. Particularly it looks most weird in designs made with Allegro: all high-speed stuff is made really nice, and the rest including polygonal layout is just a crap. It will be also really good to learn how to do footprints for parts like on pics below(my own 3D models are attached), of course with overriding manufacturer's recommended land pattern.
ID:	3413 Click image for larger version
                          • #28
                            [QUOTE=EVW13;n3411]Hi ljo, please review my comments below:
                            if i understand L version is for high density placement so i my case under the GBA. If i use L version I hope i will have no problem with the assembly . I will not assembled by hand i will send the board to a company specialized in assembly. do you think it will be ok?
                            I tried the component wizard in circuitmaker for a cap0402. you can see the result in the picture:
                            i see there is a difference in the solder mask layer compared to the capa in the community:
                            it is normal? what is the right way?
                            • #29
                              I have also question about capa0402 from the community. For the L and N version, the 3D model seems to be larger than the pad in the L version. Is it normal? See the picture below:
                              L version:
                              N version:
                              • #30
                                If you do nice courtyard and do placement without overlapping there will be no problem at all.
                                [ATTACH=CONFIG]n3420[/ATTACH]
                                In terms of PLE output(copper/geometry) all they looks wrong, however upper one looks more realistic compared to lower. I've noticed that wizard from Altium/Circuitmaker tries to arrange pads mostly under package for L, which is strange. And meaning soldermask openings for 0402: 0.05mm is good start, less is better, more isn't acceptable- on your pic opening is greatly oversized.
                                L version:
                                [ATTACH=CONFIG]n3423[/ATTACH]
                                N version:
                                [ATTACH=CONFIG]n3424[/ATTACH]
                                If 3D models are really different that is serious mistake.
