Use differential switch with 2 single-end signal
  • Filter
  • Time
  • Show
Clear All
new posts
  • Use differential switch with 2 single-end signal
    Hi everyone,
    Is there any problem if I use a differential signal switch with 2 single-end signals example this switch: PI3DBS16212ZBBEX Diodes Incorporated | Integrated Circuits (ICs) | DigiKey
  • #2
    I would probably ask the company - just in case as it's not clear what exactly is inside of the chip.
  • #3
    I would simply say that as long as you stay within the operating specifications (voltage, current, etc.) there is no problem driving single ended signals through this switch.
    As Rick Hartley stated some times, differential signals on a board are like two single ended signals as each of them references the return plane and hardly each other (<5%).
    • Tanachai Limpisawas
      Tanachai Limpisawas commented
      Editing a comment
      Thanks, qdrives. I have asked the vendor as Robert suggestion and found the example switch has a common-mode detection circuit, and the impedance 20kOhm between them. Then I plan to add the additional switch to handle the single-ended signal instead.
      ref : https://community.nxp.com/t5/Other-N...M/td-p/1510760
Working...
