GND polygons
  • Filter
  • Time
  • Show
Clear All
new posts
  • GND polygons
    Is it wrong to join the grounds in a polygon like the picture below. Same goes on the ground pins on the ISL 6236 which are adjacent. I can think of it having extra capacitance between the ground layers linked by a via which is inductor and forming a resonant circuit in high speed but other than that in low speed I don't see any problem. May be it is also bad for solder paste and reflow. What is your opinion about it?
    Added after the Question: I see at minute 20:18 of the video for the chip GND pin the data sheet says connect to the GND of the chip and done individually each pin to the pad. Now if we make a polygon and connect both to the pad would we be breaking a rule? It would be a less resistive GND connection. Just curious why we don't do that other than reflow reason or being ugly.
  • #2
    Minute 48 on the lesson on improving GND explains it. I have no question except if it is a good thing to polygon chip pins if they are same or would it be a bad practice.
    • robertferanec
      robertferanec commented
      Editing a comment
      Do you have a picture?
  • #3
    Oki, perfect, that the video explained it If you have any other questions, let me know.
    Working...
