mcu , rx , tx
  • Filter
  • Time
  • Show
Clear All
new posts
  • mcu , rx , tx
    hello everyone ,
    i'm a beginner with altium , tx pin has no driving source when i put it output ,, and when i changed to input i had no warning .
    the same thing with sim 800 , the error is he same with pin tx when it is output .
    so i can't have a communication between the two .
    why this error appear ??? how can i solve it ???
  • #2
    Hello samfe. We do not set pin types, we keep them all passive. The main reason is, that a lot of pins can have alternate functions and it was causing a lot of problems - especially during Error Check. Using PORTs can help you with Error Check a little bit (e.g. altium can check if multiple output PORTS are not connected together), but this PIN/PORT checking is not implemented very good in Altium. Maybe they improved it, but just couple of days ago I have seen similar post: http://www.fedevel.com/designhelp/fo...le-input-ports
    • #3
      thank you robertferanec
      Working...
