Zero ohm resistor?
  • Time
  • Show
Clear All
new posts
  • Zero ohm resistor?
    I was looking at the beaglebone black schematic and I saw a lot of zero ohm resistors. What is the purpose of these resistors?
  • #2
    In general they give you lots of flexibility with the board. If you don't have the resistor, you will have the two nods connected simply by a track lets say. When you use a zero ohm resistor, the circuit works the same way, however you can do stuff like:
    - Disconnect a particular block of the circuit simply by unsoldering the resistor. Otherwise you would need to cut the track, which is not very elegant and easy to fix - apart from that could be impossible if the track is on an internal layer of the board.
    - Removing the resistor and connecting an amp meter in series, to measure the current flowing through that net (I believe that is potentially the idea of R6 above).
    - Being able to split a net going to two different places, using a cross road with two zero ohm resistors. That way you can connect either of them, both of them or none.
    - Being able to change the value of the resistor to something different than 0 ohm in case you decide you need to.
    The 0 ohm resistors are mostly used with inital/debug versions of the boards since many things are unknown and need to be tested. Once a board is fully tested and ready for mass production, the number of 0 ohm resistors can be reduced.
    • #3
      thank you mairomaster for the answer.
      Ok I understand. So In my case, it is not necessary for the board to work. I am doing my first PCB with the AM3358 TI SOC. I just want to make it work based on the beaglebone black PCB and the am3358 Starter kit PCB.
      Working...
