Electronic products management and usefull skills
  • Filter
  • Time
  • Show
Clear All
new posts
  • Electronic products management and usefull skills
    Hi everyone,
    I am new to the forum and to the PCB design, currently working as Junior Hardware engineer at a medium sized brazillian company.
    The courses from fedevel academy helped me a lot to improve my skills though some little tricks inside the courses were specially helpfull.
    Where I work the cost of final PCB including components should be as small as possible because of the high volumes of PCBs so I wonder is there any method or general guidelines for doing that ? Where I could learn more about how to reduce costs on a PCB project ? So far I havent found any good material.
    Simple tricks like using 50V capacitons instead of 16V or 10V can save a LOT of money and free room for other improvements in other areas or even new projects.
    Also I would like to know if there is any course, trainning or material, which guides developers and managers through the management process of a new electronic products project. I think it would be good to follow a more structured project management when developing new project.
    Best Regards to all
  • #2
    Hello Erick Setubal there are more areas where you can save significant amount of money. For example:
    - PCB
    if you go for very high volumes, I would recommend to discuss your PCB with PCB manufacturer. They can recommend some design changes which can optimize PCB manufacturing process and make the PCB cheaper (e.g. panel size optimization, V-Scoring vs Milling, VIA size, Minimum recommended track/gap, using blind and buried VIAs, PCB material, number of layers, PCB color, .....).
    - Schematic
    About components and schematic - that may be sometimes tricky. For example sometimes it is very hard to say how many decoupling capacitors and what values is still good enough to have reliable and working design. Also, normally I try to use as few different components as possible (e.g. invertor can be replaced by NAND, 100nF/16V capacitor by 100nF/50V - as you already mentioned) so we can buy them in higher quantity and that means cheaper. Of course, watch the price of the most expensive components and choose the right one. What you can do - is to make a working design first, and then optimize it. We also often create different Variants of one board - a cheap one, middle one and most expensive one.
    - Replacement & Suppliers
    A lot of cost optimization can be done by finding a cheaper replacement (not directly changing schematic, but checking suppliers) - e.g. capacitors are good example. Sometimes you can buy one for $1, but when you find the right value / voltage / manufacturer, you can safe half of the price.
    - Assembly house
    There are sometimes big differences in price for assembly. Again, after you run the first prototype manufacturing, ask your assembly house for recommendations to optimize the assembly process. Some of the recommendations are: not placing components close to the PCB edge, not placing SMT close to through hole pins, ..... The assembly house will exactly tell you what kind of problems they had during manufacturing and what took a lot of time to do it or fix it.
    - Testing
    Design a simple and quick production test - time is money
    Probably, the most helpful would be a list of recommendations from PCB manufacturer, Assembly house, ... if you find some, please let me know. I would like to have one too. Thank you.
    Working...
