12L HDI stackup
  • Time
  • Show
Clear All
new posts
  • 12L HDI stackup
    Hi all,
    I am trying to find stackup which would be similar to stackup No 3 on http://www.fedevel.com/welldoneblog/...your-projects/. This stackup was used on Advanced PCB Layout Course. To complete Lesson 3, I have to do all track impedance calculation on similar stackup. Since I am having troubles finding similar stackup (12Layers, uVias, buried Vias etc), I need some alternative stackup. I suppose that only difference will be dielectric used.
  • #2
    Hello Milos, why can not you use one of the stackups from the article?
    • #3
      Ok, I'll do that. Thanks
      • #4
        I calculated stackup using http://www.fedevel.com/welldoneblog/...-12-Layers.pdf. I checked all the impedances. They definitely calculated impedances on L3 and L10 using only base copper weight (18 um).
        • #5
          Hi milos.stankovic, please could you be more specific? Something doesn't look correct? I believe, the suggested stackup should be the one which was suggested by the PCB manufacturer. But Martin can confirm it, I will double check.
          • robertferanec
            robertferanec commented
            Editing a comment
            Martin confirmed, that this stackup was used and the numbers should be correct. If you have any specific questions / calculations let me know. We have got the numbers for PCB manufacturer, so they may be a little bit different comparing to the theoretical numbers.
        Working...
