Remove component without removing footprint
  • Remove component without removing footprint
    Need an easy way to remove the component without removing device footprint. Tried a variant - of not fitted but the component is still there in 3D model.
    Guess I could place footprint instead of component but that's a big hassle as some are IntLib ...anything else ?
    Many thanks , Leighpots
    I wouldn't advice that. For a proper design in Altium you always want to keep a good synchronisation between schematics and PCB. Why do you need to delete a component a still keep the footprint? Maybe there is a different solution about that.
      leighpots, you need to select variant in the PCB, then it works.
Name:	pcb variant altium.png
        Thanks Robert and Mariomaster,
        We wish to export 3d model without the components to another package ...
        From the schematic I can make variant not fitted and update PCB however it still shows up
        I can find it under project variants in the pcb fie and make sure that Variant 001 is selected not fitted and the component is unlocked. .
        But the component body is still there in 3D
        I check Variant options - hide not fitted components still cannot get rid of it. I think this only applies to fab drawing but what the heck.
        Perhaps related - the devices do not grey out or indicate not fitted in the schematic - perhaps some other setting enabling variants ?
          Before you export the 3D model, set variant in PCB. We have done it many times, works oki. Maybe you are using an old Altium?
          • #6
            Thanks - looks like the component links were blown - no matter what I did - not fitting in the variant even in the PCB - it would not actually do it.
            I wish it would warn you of unmatched links !
            I still cannot get the schematic variants to graphically DNI the schematic view however ... Let me give it a go for awhile and open a new post if I get stuck.
            Regards, Leighpots
            • #7
              You can download our open source projects and test it there: http://www.imx6rex.com/open-rex/
              • #8
                In your sch attached , I selected Demo1 as variant, c1 & c2 as not fitted but still no go . Your NF parts remain even though they are fitted.
                I only have to click OK and the changes should be made ?
                Maybe another bug in my version of altium ?
                • #9
                  leighpots, this will explain it to you: Altium Tutorial – Variants & Printing PDF Schematic
                  • #10
                    Ah that little trick ... all the best regards, Leighpots
