If a BGA chip has several pins in a row all connected to the same power net, is it recommended to provide a via to each of them, or is it ok for two or three power pins to share the same via?
Via placement for BGA power pins
It depends how much space you have available. If you have plenty of space, use a separate via for each pin. Otherwise it's normally alright to combine 2/3 pins. Also it depends on how much current they carry and how much noise tolerant they are. With a low current and less sensitive rail you can safely combine more pads.
- 1 like
