PCB Stack Impedance issue
  • Time
  • Show
Clear All
new posts
  • PCB Stack Impedance issue
    Hi there,
    I am preparing to design an iMX6UL development kit.
    My PCB stack is 4 layer.
    L1 (signal)
    L2 (GND)
    L3 (POWER)
    L4 (signal)
    Should i have to control impedance on both of layer when routing DDR3? Assume that the track what has 50Ohm impedance in layer 1 is 0.12 mm width, but 0.12mm track is not 50Ohm impedance in layer 4. So that what will i have problem if i route 0.12mm track for DDR3 signal in layer 4?
    Thank you for your help!
  • #2
    You definitely need impedance control on all layers where you are routing DDR3 signals. L4 will normally use the L3 power layer as a reference, so you should be having the same track parameters.
    Despite the reference design for iMX6UL from NXP being done on 4 layers (if I remember correctly), this puts some limitations on what you can do on the board and will be quite challenging as well, if you don't have much experience designing such boards.
    • #3
      I agree with mairomaster.
      PS: This iMX6UL design confused a lot of people. If you would like to use POWER as a reference plane, be sure there are a lot of decoupling capacitors between the plane and GND and also be sure this plane is above all the memory tracks.
      • #4
        Thank you mairomaster and robertferanec,
        Exactly, the reference layout is 4 layers. I checked reference layout and reference design and i did not find some decoupling capacitor such C101, C102. I guest that it was be removed.
        This is my very first high speed design. So that i will try to route with 6 layers PCB. Base on robertferanec 's guide in his course, I define my PCB stack like attachment.
        Do you have any comment for my further work?
        • #5
          6 layers could help. Be sure you know track geometry on top and bottom layer for all the impedances you need. Double check the stackup and impedances with your PCB manufacturer.
          • #6
            robertferanec Thank you, I worked with 8 layers.
            • #7
              i got the pcb.
              Now, i have trouble while debug it. I used Mfg tool from NXP.
              when i upload uboot into kit, i received error about initializing memory. Below is MFG log and config. Pls, give me some advice in this case.
              MFG log
              Code:
              DLL version: 2.6.2
              Friday, June 30, 2017 10:22:44   Start new logging
              ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
              ModuleID[2] LevelID[1]: new MxHidDeviceClass
              ModuleID[2] LevelID[10]: new MxHidDevice[04718FB8]
              ModuleID[2] LevelID[10]: new MxHidDevice[04719488]
              ModuleID[2] LevelID[10]: new MxHidDevice[047BF6D8]
              ModuleID[2] LevelID[10]: new MxHidDevice[04819050]
              ModuleID[2] LevelID[10]: new MxHidDevice[04842A38]
              ModuleID[2] LevelID[10]: new MxHidDevice[0483D730]
              ModuleID[2] LevelID[10]: Device Manager thread is running
              ModuleID[2] LevelID[1]: Can't set m_hStopEvent before it initialized or it already stop
              ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
              ModuleID[2] LevelID[10]: CmdOperation[0], skip current command, so SetEvent(hDevCanDeleteEvent)
              ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is C:\Users\Huypq6\Downloads\L4.1.15_1.0.0_ga-mfg-tools.tar\L4.1.15-1.0.0_ga-mfg-tools\mfgtools\Profiles\Linux\OS Firmware\firmware\u-boot-imx6ul14x14ddr3arm2_sd.imx
              ModuleID[2] LevelID[1]: MxHidDevice::Write() Error writing to device 0x1f.
              ModuleID[2] LevelID[1]: Failed to initialize memory!
              ModuleID[2] LevelID[1]: PortMgrDlg(0)--MxHidDevice--Command Boot excute failed
              ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
              ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_007D#6&106a4439&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
              ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - end
              ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_007D#6&106a4439&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
              ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
              ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&PID_007D\6&106A4439&0&2, _deviceInstanceID: USB\VID_15A2&PID_007D\6&106A4439&0&2
              ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
              ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_007d, Hub:6-Port:2
              ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
              ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
              ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
              ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Remove
              ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
              ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
              ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
              ModuleID[2] LevelID[10]: delete MxHidDevice[0483D730]
              MFG config
              Code:
              [profiles]
              chip = Linux
              [platform]
              board = SabreSD[LIST]
              name = SDCard
              [variable]
              board = sabresd
              mmc = 0
              sxuboot=sabresd
              sxdtb=sdb
              7duboot=sabresd
              7ddtb=sdb
              6uluboot=14x14ddr3arm2
              6uldtb=14x14-ddr3-arm2
              ldo=
              plus=
              initramfs=fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.gz.u-boot
              seek = 1
              sxnor=qspi2
              7dnor=qspi1
              6ulnor=qspi1
              nor_part=0
              • #8
                I am not sure. I do not use latest MFG tools. I use this: http://www.imx6rex.com/open-rex/soft...setup-mfgtool/
                Working...
