i am trying to design a power supply using PMIC's from Linear Technology,in the datasheet there is a distinction between signal and power grounds, it says make them separate and connect them at a single point only, i understand the need to separate them but my questions is, is it a good idea to assign one ground plane to signal ground another to power ground and use a via to connect the two? or is there another way to implement this concept?
Natnael,
Natnael,
