Hey everyone!
I have another question incase anyone has ran into the same issue and able to solve it!
I have taken over some projects done by another individual and I'm using "Draftsman" to populate the assembly drawings. It seems to be pretty clean and has worked pretty well except for a couple little glitches here and there. The issue I have ran into is occasionally a 3D component will not display on an Iso or side profile. All the components that had a "3D" footprint created in the PCB library seem to be showing up, but when I try and manually create a "3D Body" on the PCB it doesn't want to display.
I would also note that I do not have access to the original PCB library used for these projects. I have attempted to save, regenerate the "Iso" image and Updated the board.
I'll attach a couple images to help show and explain the issue.
Thanks for any input!
Josh
Josh
