28 pins Project
  • Filter
  • Time
  • Show
Clear All
new posts
  • 28 pins Project
    Hello Everyone !!
    Hello Robert !!!
    Could you help me ?
    In arduino 28 pins Project We use via with 0.3mm hole size ....
    I was watch notes about hardware design, Via Aspect Ratio.
    My questions is ...
    1. What kind of vias We use in this project ? I think ... Blind vias ??? . Am I correct ?
    2. The thickness of board is 1.6mm , Is enough to use a Via this type to connect TOP e BOTTOM Layer ?
    Sorry I'm a little confuse about this
    Thank you
  • #2
    1) Through hole VIAs.
    2) It is fine. Usually the ratio is 1:10 or 1:12. For this kind of board, usually the smallest through hole can be 0.15mm .... this means, 0.3mm is perfect and it is also cheap.
    Working...
