Hi all, i have a question about a design that i have seen on a card. The designer use an AOP in voltage follower mode (yellow in picture). What is the utility of it ? Protect the micro ADC ? Otherwise, can you said me if the couple R1/C1 is really necessary in this mode? I ask this question because i would like to start a new design from this one but decrease the cost (if possible).
AOP with micro ADC
Here you can see the basic applications of OP AMP: https://en.wikipedia.org/wiki/Operat...r_applications
If you have a look, your application is combination of several circuits - depends what components you will fit, but basically, it is an Non-inverting amplifier (and without R3 fitted, output will just follow the input - from "voltage follower": "Used as a buffer amplifier to eliminate loading effects (e.g., connecting a device with a high source impedance to a device with a low input impedance)."). Because of the capacitor it will also have some Low Pass Filter capabilities: https://www.electronics-tutorials.ws.../filter_5.html
protect ADC from hightvoltage (from exemple 24v in AIN1)
