Unfortunately I carried DRC violations whilst completing the PCB design. Please see the attached images of my design so far.
It is clear the GNDs are not connected but I don't understand why. There is probably something really simple missing. Please note I changed the colour for connection of the GNDs much later in the design. This may have caused the issue. I didn't follow your video absolutely which was my mistake.
I have two different layers for GNDs in my PCB but in the schematic the same GND symbol was used for all the GND connections. This has further confused me. Should the vias for the GNDs be going all the way through the board from the top to the bottom and connecting to both GND planes? You state in the videos that there are two seperate grounds. I am not sure what I have done.
Please note I am using Altium 2018 (18.1.9) which looks quite different for some of the menus so it is also quite likely I got one of the settings wrong.
Any help you can provide would be most appreciated.
Regards,
Dale
Regards,
Dale
