Antenna tunning/ matching circuit
Yes becuse normally you have a design guide to follow and the passive values for have a correct matching.
For tuning an antenna you need to set up a test like this in the video: https://www.youtube.com/watch?v=k2VVtKaysLo . You need to start with some passive values (taken from some reference sample), take the measure and the try to change they. When the resonance reach the better result you have matched the antenna.
Thanks for your answer ypkdani .
I know that if we use a pi matching circuit for the antenna, we can tune that components for the right impedance.
My question is how can I do a right measure of the impedance, what is the procedure?
There is some techniques?
Thank you!
for design an antenna, or place a ceramic antenna, on your pcb you need to:- have a region where to put that, normally without ground plane around or on the other layer down that
- if you use a ceramic antenna you need to follow the application note that explain you ho to match the antenna an how to design the pcb around that
- if you design the antenna normally you find some application note from TI or other manufacturer that had already design that
Design a good antenna normally is not simple because all the things around it influence it, and you need some basic instruments (for first a spectral analyzer), so in my projects i had used ceramic antenna
Hello all,
I want to produce a device with Bluetooth and GPS, so I need to place an antenna on PCB (ceramic or PCB antenna).
I know that there is a matching circuit to tune that. How can I tune that to properly work on that frequencies?
Thank You!Tags: None
