How to use resettable fuses?
  • colhany
    Thank you very much, Mr Robert
    Often, the regulators itself have a protection for shorts - means if there is a short, the voltage will not even come up (or only for a very short period of time). We often use fuses for overload protection (e.g. something drives higher currents than it should - but it is not necessary a short circuit).
  • colhany
    Thank you very much
  • qdrives
    So it is the speed?
    That also depends on the load profile. If you have soft-start or not.
    The fastest is electronic. Both resettable and non resettable fuse are driven by temperature. So it needs to heat up first.
    The (glass) fuses are - simply speaking - in fast and time lag variants. The fast can open in 10ms.
    https://www.littelfuse.com/media?res...-448-datasheet
  • colhany
    So non resettable fuses are fast enough to protect against shorts?
  • qdrives
    All depends. A PTC is slow, has a maximum voltage and a (high) resistance.
    I have used a resettable fuse more for long term overload and not so much short circuit protection (going external).
    E-fuse are components that can fail too.
    Most fail safe are the non-resettable fuses.
  • colhany
    started a topic How to use resettable fuses?
    Hello everyone
    i wanted to know how to use resettable fuses in a PCB?
    Do I just connect them in series with the supply or are there additional components needed?
    And is a fuse enough for short circuit protection, or is it better to use something like an E-Fuse ic?
    Thank you
