Decoupling capacitors placement
  • Decoupling capacitors placement
    Hello Robert,
    Firstly, thanks a lot for your excellent work all these years.
    My question is about a strange placement of decoupling capacitors that i have seen in the following video:
    Detailed teardown of the new generation Tektronix 2 Series MSO bench/portable battery powered oscilloscope!An innovative new design form factor you're either...
    This video is a teardown of a Tektronix oscilloscope.
Name:	bottom tektronix.jpg
    In the capture attached, If you look at the decoupling capacitors, they are located exactly above the vias. And this happens for the memory chips (DDR4) and FPGA (Xilinx Ultrascale)
    What is your opinion about it? Is it possible to do this placement of the decoupling capacitors?
    Thank you very much in advance
    See my EDICON paper on partial inductance this minimizes the mount portion if the inductance, making the capacitor much more effective at high frequencies (DDR, FPGA, etc)
      As long as the via's are either:
      - Filled and capped
      - Solid copper fill
        Thank you very much for your answers
          Bermell it is possible to do via in pad ( as qdrives mentioned ). It has some advantages, as Steve.Picotest already mentioned, it is better way to connect decoupling capacitors and also sometimes it's done this way if there is no extra space for additional pads. However, it is more expensive, that is why it's not on many boards.
          • #6
            Thank you very much Robert
