Single DDR3 routing
    commented on 's reply
    E.g. Freescale / NXP has something: Hardware and Layout Design Considerations for DDR4 SDRAM Memory Interfaces http://www.nxp.com/files/32bit/doc/a...n&fileExt=.pdf
    In fly-by you can do this between group length matching in the first segment of signal (the place between CPU and first memory chip) e.g. make the first segment of CLK a little bit longer than ADDR/CMD/CTL group, then CLK will always arrive a little bit later then ADDR/CMD/CTL.
  • JohnsonMiller
    In DDR2/DDR3 T-branch routing there are two sets of constraint: 1) inside group (ex. data lines), 2) between groups. For example clock signal need to have some relation with DQS. Question is that in Fly-by routing of DDR3 it is not possible to follow this rule! Am I missing or misunderstanding something?
  • JohnsonMiller
    From board design point of view, what is major difference between DDR3 and DDR4? Can you recommend a tutorial of help document?
    mairomaster is right. Everything is correct except the typo in 4). Tolerance should be followed according to the chip manufacturer (sometimes the numbers are different). Normally we use:
    - "within 5 mils" between P/N of differential pair,
    - "within 10 mils" for Data group (we keep DQS longest from the group)
    - "within 20mils" for ADDR/CMD/CTL group.
    Have a look at this iMX6 Design guide and if you do not have any other documents, you could possibly use it as a reference (page 40): http://cache.freescale.com/files/32b...6DQ6SDLHDG.pdf
Name:	ddr3 length matching rules.jpg
  • mairomaster
    I think you got it right, just for 4) it is cock pair, not clock enable pair but I guess that is just a typo.
    The tolerance should be specified by the manufacturer of the FPGA you are using. Standard values that I am using are something like withing 0.5 mm (+/- 0.25 mm) for the signals withing a group and 0.2 mm withing a differential pair (+/- 0.1 mm between the positive and negative signal in the pair).
  • key2
    started a topic Single DDR3 routing
    Single DDR3 routing
    I am doing an opensource FPGA + DDR3 design, I was watching your great tutorial about routing with altium and particularely the tutorials about DDR3 routing, but one thing that is not clear:
    When you have a SoC or FPGA connected to a single DDR3, what are the groups ?
    If I got it well:
    1) data0-7 + dqs0_pair + LDM
    2) data8-15 + dqs1_pair + UDM
    3) ADDR0-x + BA0-2 + RAS/CAS/ODT/CKE/WE
    4) DDR CKE_pair
    Am I correct or could it be split more than that ?
    What is the tolerence that is acceptable ?
    regards
