Distributor Part Update
    commented on 's reply
    I am curious. please post it. Thank you.
  • lanuser
    Hi lanuser, did you try:
    - Schematic: Update from Libraries -> Fully replace symbols and sheet with those from library ("check" all) -> Next.
    - "Check" all the symbols you would like to replace.
    - Select a component (s) -> Click on "Choose Component" button. Find it in the library and select the new component.
    - Check "Library Name" and "Logical Symbol", if they are correct
    - Finish ...
    Please, let me know if this is what you were looking for. I hope it will help
    Note: You may need to install the library first. Go to your Schematic: Design -> Add/Remove Library
    [ATTACH=CONFIG]n315[/ATTACH]
    [ATTACH=CONFIG]n316[/ATTACH]
    Your answer are Incorrect.....
    I found the solution ... and will post later on today.
    - Finish ...
Name:	Update from library 1.png
Name:	Update from library 2.png
  • lanuser
    started a topic Distributor Part Update
    I have question regarding altium.
    Let say I have 20 schematic sheets and each sheet has exact same 5 component.
    Now time pass and this component no loner available from the supplier.
    Now I have added new component that has exact same value but has different part number and different manufacturer.
    Question is:
    How can I change outdated component in 20 schematic sheets with new component without going to each sheet and changing each component manually.
