Minimum and maximum clearance
I think that is a bit unusual, why do you need to do that? Maybe there is an alternative solution.
The standard clearance rule allows you to only set minimum clearance. If the tracks are a part of a differential pair, you can use the differential pairs routing rule to set a maximum gap. If they are not, you can present them as a differential pair, although it will be a bit strange. This is the only way I can think of.
Is there a way to set a rule for minimum and maximum clearance at the same time. I would like 2 traces to have a minimum spacing 0.1mm and a maximum spacing 0.4mm.
Thank youTags: None
