Polygon Pour Clearance
    Maybe you can setup a rule - VIA to VIA and set minimum clearance between them to the value when you know the copper will flow uninterrupted between them. Just an idea.
  • Michael Karl
    Thank you for this advice.
    We always check this visually/manually. I am not sure if there is a rule for this.
  • Michael Karl
    started a topic Polygon Pour Clearance
    Hello
    I have a question about flooding planes between VIAs.
    In the photo you can see a clearance from 0.07mm. This is for the PCB-manufacturer too small.
    Even the DRC could not find this.
    I did designs with FPGA and DDR3 where a lot of VIAs are and I have also a lot of this too small clearances between the VIAs.
    Can I set somewhere a rule to ckeck this?
    Otherwise I have to manually inspect all my planes.
    Sorry for my poor english. I am from Austria.
    Many thanks in advance
    Mike
